Using Mote with Homekit and Siri
Because Mote was designed for home lighting, like under-shelf or under-cabinet lighting, automating its control opens up a lot of possibilities.
Fortunately, Apple's Homekit API has been extended with an open source project called homebridge, a Node.js library with a bunch of useful plugins for controlling everything from RGB LED lights, like Mote, to Sonos speakers, and even the Xbox One.
Although Apple will shortly be releasing a Home app (alongside iOS 10) to allow you to control Homekit-enabled devices, there are a number of other apps that allow you to do the same. Our favourite is one called Hesperus, that offers a clean, intuitive interface with options for setting up scenes with groups of devices and scheduling actions.
(UPDATE: Apple have now released their Home app, and we can confirm that it works nicely with our Mote API described below)
Here, we'll look at how to set up a Flask API to control Mote, how to install and configure homebridge and the homebridge-better-http-rgb plugin, and how to use the Hesperus app and Siri to control Mote.
UPDATE: You can now use the Apple Home app to do everything that Hesperus does, with better integration with Siri and other iOS features.
Installing the Mote and Flask Python libraries
We need a couple of Python libraries - the Mote and Flask libraries - so let's install those now, before we begin going through the code.
If you're setting this up on a Raspberry Pi, and we'd suggest that this is the best way to do it, then you can use our one line installer to install the Mote library, as follows.
curl https://get.pimoroni.com/mote | bash
If you're not using a Raspberry Pi, then you can use pip, the Python package installer, to install the Mote library.
sudo pip install mote
We also need to install the Flask library, and we can also use pip to install that. Type the following to install Flask.
sudo pip install flask
Writing a Flask API for Mote
The homebridge plugin that we'll be using to receive messages from Hesperus and Siri is called homebridge-better-http-rgb. It uses a series of endpoints to relay commands to RGB LED lights. Our Flask API will define these endpoints and use them to switch the Mote LEDs on and off, control their brightness, and control their hue.
The endpoints defined by homebridge-better-http-rgb are on, off, status
(whether the lights are on or off), brightness, and set to set the hue. The
brightness and set endpoints, when called without a subsequent value, will
return the currently set brightness or hue respectively. Otherwise, values can
be passed to those endpoints, for example brightness/50 to set the brightness
to 50% or set/FF0000 to set the hue to red.
Flask is a super little Python library for building web apps, and can also be used to build simple APIs (application programming interfaces) to let you programmatically control things, whether they be physical devices or web services.
Our Flask API is around 100 lines, so we'll go through it by bit, to see what it all does.
Imports
First, we need to import a few things that we'll be using for our API.
from colorsys import hsv_to_rgb, rgb_to_hsv
from mote import Mote
from flask import Flask, jsonify, make_response
The colorsys functions hsv_to_rgb and rgb_to_hsv will be used to
interconvert HSV and RGB colours (more on that later). We need the Mote class
to control Mote, and the Flask class and jsonify and make_response
functions to build our API.
Boilerplate
At the very top, we have some boilerplate code that sets up some things that are required by our code, to initialise the Flask app and to set some parameters for Mote.
app = Flask(__name__)
mote = Mote()
mote.configure_channel(1, 16, False)
mote.configure_channel(2, 16, False)
mote.configure_channel(3, 16, False)
mote.configure_channel(4, 16, False)
colour = 'FFFFFF'
status = 0
We configure each of the four channels of our controller each to have 16 pixels,
and then create a couple of variables colour and status, that we'll
use later on, with sensible defaults of white for the colour and 0 or off for
the status.
Mote functions
Most of the rest of our code is composed of various functions that we can split into those related to controlling Mote, and the functions that will be used by Flask to create the API endpoints.
Let's have a look at the Mote functions first.
Because our homebridge plugin expects colours in hex, and Mote expects colours
to be in RGB, we have the slightly convoluted task of interconverting these.
The colorsys library has functions to interconvert HSV and RGB values, but
unfortunately does not have a function to convert to and from hex values. So,
we'll write a simple function to convert hex to RGB.
def hex_to_rgb(value):
    value = value.lstrip('#')
    length = len(value)
    return tuple(int(value[i:i + length / 3], 16) for i in range(0, length, length / 3))
Our hex_to_rgb function takes a value, strips off the leading # if there
is one, and then splits the 6 digit hexadecimal value into three pairs of two
digits (one each for red, green and blue) and converts them into integers. The
Python int function that converts strings or floating point numbers into
integers takes an additional argument that tells it which base to use when
converting. In this case, we use 16 because we're working with hexadecimal
numbers, meaning that our two hexadecimal digits get converted into an integer
that takes a value between 0 and 255 (2^16 = 256).
Next, we have a couple of functions that switch Mote on or off. The mote_on
function takes a single argument - c - the colour as a hex value. It then
uses the hex_to_rgb function that we just wrote to get the r, g, and b
values from the hex colour c, and sets all of the pixels across all of the
strips to that colour. This function will be used to switch Mote on, and to
change the colour of Mote while it is switched on.
def mote_on(c):
    r, g, b = hex_to_rgb(c)
    for channel in range(4):
        for pixel in range(16):
            mote.set_pixel(channel + 1, pixel, r, g, b)
    mote.show()
    return True
Our mote_off function is a simple one that turns all of the pixels off.
def mote_off():
    mote.clear()
    mote.show()
    return True
Flask API functions
The remaining functions relate to the API itself, and define the endpoints that
the homebridge-better-http-rgb plugin will use. As is the convention for APIs,
all of our endpoints will begin /mote/api/v1.0/, telling us the name of the
API, specifying that it is indeed an API as opposed to a webpage, and the
version number to provide a means to have legacy support once newer versions are
developed.
On/off/status
The first endpoints that we'll define will be /mote/api/v1.0/status,
/mote/api/v1.0/on and /mote/api/v1.0/off. The status endpoint allows the
API to return the status of Mote - whether it is on or off - so we'll use our
status variable, that is either 0 when off or 1 when on, and set that as
part of a get_status function.
def get_status():
    global status
            if mote.get_pixel(channel + 1, pixel) != (0, 0, 0):
                status = 1
                status = 0
    return status
Our function defines status as a global variable, so that its state persists
across all of the code, inside and out of functions. It then loops through all
of the pixels on all of the channels and then checks whether they are on or off.
If they are on, then status is set to 1, otherwise status is set to 0.
We'll use that function that we just wrote in the first of our routes, in a
set_status function. In Flask, endpoints are wrapped in a @app.route
decorator that defines it as a URL route.
@app.route('/mote/api/v1.0/<string:st>', methods=['GET'])
def set_status(st):
    global status, colour
    if st == 'on':
        status = 1
        mote_on(colour)
    elif st == 'off':
        status = 0
        mote_off()
    elif st == 'status':
        status = get_status()
    return jsonify({'status': status, 'colour': colour})
Our app.route decorator defines the URL structure as
'/mote/api/v1.0/<string:st>'. The first part - /mote/api/v1.0/ - will be
common to all of our URL endpoints. The <string:st> part is a cunning little
trick that Flask uses to grab part of a URL and assign it straight to a
variable, and even lets you set what the type is, in this case a string called
st We also use methods=['GET'] to specify that this URL will send a get
request.
The set_status function is passed the st variable from the URL and then,
depending on whether st is on, off or status, acts accordingly. If
st is equal to 'on' then the mote_on function is called with the global
colour that is currently set, and status is set globally to 1, and if it is
equal to off then the mote_off function is called and status is set to 0.
If st is equal to 'status', then we call our get_status function.
Finally, we return in JSON format the status and colour, using the jsonify
function, passing it a dictionary with the appropriate keys and values. When a
get request is sent to this URL route, the JSON-ified dictionary will be
returned rather than an HTML page as would normally be the case.
Getting and setting colour
homebridge-better-http-rgb specifies that the /set endpoint will return the
currently set colour. We'll write a simple route function that returns the
global colour value and returns it in the same JSON-ified format as our last
route that we wrote.
@app.route('/mote/api/v1.0/set', methods=['GET'])
def get_colour():
    global colour
Again, we use the @app.route decorator to set the URL to be
'/mote/api/v1.0/set' and specify that it will send a get request. The
get_colour function that is called when the URL is accessed simply returns
the JSON-ified dictionary containing the status and colour.
We also need a set_colour function that will be used to... set the colour! It
extends the /set route with a hex colour, e.g. FF0000 for red.
@app.route('/mote/api/v1.0/set/<string:c>', methods=['GET'])
def set_colour(c):
    colour = c
    if status != 0:
        mote_on(colour)
        status = 1
We grab the hex colour from the URL and assign it straight to a variable c as
part of the route decorator, then pass it into the set_colour function. We
specify that status and colour are globals and then set colour to be the
same as c. If status is not currently equal to 0, i.e. if it is currently
on, then we call our mote_on function and pass it the colour, then set
status to 1. Last, we return a JSON document, as we did with our previous
endpoints.
404
To do things by the book, we'll use Flask's @app.errorhandler decorator to
gracefully handle 404 not found errors.
@app.errorhandler(404)
def not_found(error):
    return make_response(jsonify({'error': 'Not found'}), 404)
If a route isn't found, then a JSON document will be returned informing the human or non-human user that the route doesn't exist.
The main function
In Flask apps, the main function is run when the app is first run at the
command line. As well as actually running the app with
app.run(host='0.0.0.0', debug=True), we'll call the mote_off() function to
switch Mote off when the script is first run. This is a good idea because the
state of the pixels, i.e. whether they are on or off and their colour, will only
persist as long as the app is running. If they were switched on and the app
stopped running, then when the app was run again it would assume they were
switched off and had the default white colour. By setting them to off when the
app first runs, we get over such problems.
if __name__ == '__main__':
    mote_off()
Testing the API
Now that we've written our API, we can test that the endpoints work as expected.
The entire code is below, so copy it and save it in a file called something like
mote_api.py.
mote = Mote()
colour = 'FFFFFF'
status = 0
    length = len(value)
def mote_on(c):
    mote.show()
    return True
def mote_off():
    mote.clear()
    mote.show()
    return True
def get_status():
    global status
                status = 1
    return status
def set_status(st):
    if st == 'on':
        status = 1
        mote_on(colour)
    elif st == 'off':
        status = 0
        mote_off()
def get_colour():
    global colour
def set_colour(c):
    colour = c
    if status != 0:
        mote_on(colour)
        status = 1
    mote_off()
Open a terminal and type 'python mote_api.py'.
Then, open another terminal window or tab, and type the following to test that our API is working as expected.
curl -i http://127.0.0.1:5000/mote/api/v1.0/on
That should have just turned your Mote strips on! You should also be able to
do this remotely, on another machine, replacing the 127.0.0.1 part of the URL
with the IP address of the machine on which your API is running. You should also
be able to do this in your web browser rather than with curl in the terminal.
Try typing the following to change the colour of the Mote strips to red.
curl -i http://127.0.0.1:5000/mote/api/v1.0/set/FF0000
Setting up homebridge and homebridge-better-http-rgb
The next step is to set up homebridge and homebridge-better-http-rgb on our machine running the Mote API, to complete the circle. homebridge and the homebridge-better-http-rgb plugin provide the means to add Mote as a Homekit device that can be controlled through an app like Hesperus, and send commands to our API and hence to the Mote strips.
The following instructions assume that you're using a Raspberry Pi 3 running the latest version of Raspbian Jessie although, with some modifications, you should be able to run everything on a Mac, a Windows PC, or another Linux machine.
The version of Node.js bundled with Raspbian is a little out of date, so we'll install the latest version before we start to install homebridge, etc.
Open a terminal, and type the following to upgrade to the latest and greatest version of Node.js:
sudo apt-get update
sudo apt-get upgrade
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
sudo apt-get install -y nodejs npm
Before we install homebridge, we'll also need to install a couple of dependencies. Type the following to install them:
sudo apt-get install libavahi-compat-libdnssd-dev
Now, we can install homebridge itself, as well as the homebridge-better-http-rgb plugin:
sudo npm install -g --unsafe-perm homebridge
sudo npm install -g --unsafe-perm homebridge-better-http-rgb
Now that everything is installed, we have to do a couple more things to
configure homebridge correctly. homebridge is configured through a .json file
that must be put into the /home/pi/.homebridge/ directory. We'll create that
directory now:
mkdir /home/pi/.homebridge
Here's what our config file looks like:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:32",
        "port": 51826,
        "pin": "031-45-155"
    "description": "Homebridge",
    "accessories": [
            "accessory": "HTTP-RGB",
            "name": "Mote",
            "service": "Light",
            "switch": {
                "status": "http://127.0.0.1:5000/mote/api/v1.0/status",
                "powerOn": "http://127.0.0.1:5000/mote/api/v1.0/on",
                "powerOff": "http://127.0.0.1:5000/mote/api/v1.0/off"
            "brightness": {
                "status": "http://127.0.0.1:5000/mote/api/v1.0/brightness",
                "url": "http://127.0.0.1:5000/mote/api/v1.0/brightness/%s"
            "color": {
                "status": "http://127.0.0.1:5000/mote/api/v1.0/set",
                "url": "http://127.0.0.1:5000/mote/api/v1.0/set/%s",
                "brightness": true
    "platforms": []
Copy and paste that, and save it as config.json in the /home/pi/.homebridge/
directory that we just created.
You can change the bridge name and description to whatever you'd like, as well
as the accessory name that we've called "Mote". The username, port and
pin are all boilerplate values and can be left as they are.
If, at a later date, you wanted to add other accessories using other homebridge
plugins, then you'd add them as new accessories in the accessories list.
Now that everything's set up, we'll start the Mote API first and then homebridge.
Assuming your Mote API is called mote_api.py and is in /home/pi/, type the
following to start it:
python /home/pi/mote_api.py
You'll see a few lines telling you the status of the Flask app, including the IP address and port on which it is running.
Now, open another terminal tab or window (leaving the Mote API one open), and
type homebridge to start homebridge.
You'll see a few lines confirming that the Mote accessory has been loaded successfully and a code that you can enter when configuring your Homekit app on your iPhone. There's no need to write this code down, as it's the same as the one that we configured ourselves in our config file earlier.
Now that the Mote API and homebridge are running, we'll install and configure the Hesperus app on our iPhone and link it up to our Mote accessory.
Setting up the Hesperus iOS app
Hesperus is a really nice free iOS app for controlling Homekit accessories. The setup described above works really smoothly with Hesperus, but other Homekit apps like Elgato Eve and Homedash (and Apple's own upcoming Home app) should work equally well.
You can download Hesperus in the iOS App Store.
When you first open the app, you'll be greeted by a screen that asks you to "Create Your First Home".
Give your home a name. I went for the imaginatively named "Home".
Once you've done that, you'll be taken to the home page for your Home space. This is where all of the accessories that you add to that space will appear. If you decided that you wanted to get more specific, you could have separate spaces for different rooms in your house like "Living room", "Bedroom", etc. Spaces are accessed by tapping on the icon with four small squares, just below the battery status icon.
Tap the large "+" in the centre to add a new accessory. It'll scan to look for connected accessories and, assuming that the Mote API and homebridge are running, it should find the "Homebridge" bridge. Click on "Identify" to complete the setup of the Mote accessory.
It'll display a warning telling you that "This accessory is not certified and may not work reliably with Homekit". Just tap "Add Anyway".
You'll then see a screen that will allow you to use the camera to scan the PIN code displayed in the terminal window running homebridge (you may need to grant the app access to use your camera). In our experience, the camera detection of this code was a bit iffy, so you may need to click "Enter code manually" and then key in the PIN code.
Once the accessory has been successully added, you'll be taken back to the home screen for you "Home" space, and the Mote accessory should be visible.
Try clicking on it. The Mote strips should come on!
If you're using an iPhone 6 or later, you can force tap on the Mote icon to pop open a more detailed set of controls to let you change the colour and brightness of Mote.
Try tapping on the circle on the left hand side and then drag your finger around the colour palette to change the colour of Mote on the fly.
Scenes, schedules, and actions in Hesperus
You can do a lot more than just turning on Mote and controlling its brightness! Hesperus lets you set up scenes that can be triggered instantly from the scenes screen. We'll create a scene called "Good morning" that turns Mote on with an orange hue, 75% saturation and 100% brightness.
Tap on the second from left icon on the bottom bar of Hesperus (the two overlapping squares) to access the "Scenes" page. Then tap on the "+" in the top right hand corner to add a new scene.
Call it "Good morning", and tap on the "+" to add the Mote device. Make sure to toggle the power on and select the hue, saturation and brightness that you want, then tap "Save" to save your scene.
Now that you've added your scene, you can even trigger it through Siri by using its name: "Hey, Siri. Good morning."
I've added several more scenes called "I'm leaving", "I'm home", and "Good night", that all can trigger actions direct from Siri.
The calendar icon on the bottom bar (third from the left), can be used to create scheduled actions. These let you schedule actions at a specific time and frequency, for instance one called "Morning", similar to our "Good morning" scene that switches the lights on in a pale orange hue at 7am every day.
Finally, we can create actions that trigger automatically given certain condtions. For instance, we can create a "Lights On" action that will trigger if we're at home and it's after sunset.
The "Actions" page is the second icon from the right on the bottom bar (the one that looks a bit like an orange sliced through the middle). If you grant access to location data in Settings > Privacy > Location Services > Hesperus, then you can trigger actions when you are within or outside a location.
Then add a resulting action.
You can also add additional conditions with and or or Booleans, such as before or after a given time, or before or after sunrise or sunset.
Controlling Mote with Siri
The other added benefit of having set all this up is that now that we've Homekit-enabled Mote, we can control it with Siri. We can use the name that we gave our Mote accessory in the config file (in our case "Mote") to control it.
If you have "Hey, Siri" enabled, then try saying "Hey, Siri. Turn Mote on.", or press and hold the home button to launch Siri and say "Turn Mote on".
There's a little flexibility, so you should also be able to say "Switch Mote on", "Turn the lights on", and perhaps some other ways of phrasing it.
You can also say "Set the brightness to 25%", or "Set Mote to red".
And, as we mentioned earlier, you can also use Siri to trigger scenes that we created in Hesperus, e.g. "Hey, Siri. I'm home." to turn the lights on.
If you have an Apple Watch, then you can also use Siri on it to control your homebridge devices. And with Apple adding Siri to OS X, you should also be able to control them using your Mac soon.
We've only covered a basic setup with a single Mote controller, but you could easily extend this, either with additional Mote controllers on the same Pi and extending the API endpoints to include a controller number in the URL, or with additional Pis and controllers on separate IP addresses. You could also modify the API to individually control each strip on each controller.
A simple way to jazz up your Mote API would be to include a short fade up and down when you turn on or off your Mote, to make it look a bit less jarring when turning it on or off.
And, of course, the beauty of homebridge is that you could easily add more plugins and hence accessories so that you could, by triggering a single action, start your Sonos playing some smooth jazz and turn the lights on low. Nice.
