Getting Started with Rainbow HAT
This tutorial will show you how to install the Rainbow HAT Python library, and then walk through its functionality.
As with most of our boards, we've created a really quick and easy one-line-installer to get your Rainbow HAT set up. We'd suggest that you use this method to install the Rainbow HAT software.
curl https://get.pimoroni.com/rainbowhat | bash
Once that's done, it probably a good idea to reboot your Pi to let the changes propagate.
Using the software
Open a new terminal and type python
to open a new Python prompt.
To import the Rainbow HAT library, type the following in your Python prompt that you just opened:
import rainbowhat as rh
Notice that we said as rh
. That just saves us from typing rainbowhat
every
time we want to use something from the library.
The rainbow
Rainbow HAT's rainbow is a single sweep of 7 APA102 RGB LED pixels that can be controlled individually through the Rainbow HAT Python library. As is the convention in Python, the seven pixels are numbered from 0 to 6, and arranged from right to left (pixel 0 is the rightmost, pixel 6 is the leftmost).
There are two methods that we can use to control the rainbow pixels -
set_pixel
and set_all
- the former allows per-pixel control of colour, and
the latter sets all of the pixels to the same colour.
We'll begin by lighting the first pixel red. The set_pixel
function needs to
be passed four pieces of information - the pixel number, and a red, green, and
blue brightness value (from 0 to 255). Once pixel values have been set, you have
call the show
function to update the pixels and show the colours that you've
set.
Type the following:
rh.rainbow.set_pixel(0, 255, 0, 0)
rh.rainbow.show()
The rightmost pixel should just have lit red. Notice that we typed
. All of the functions related to the
Rainbow are collected together into a module called rainbow
, hence why we had
to type rh.rainbow
before the name of the function we wanted to use.
Now, let's get a little more advanced and try making our red pixel scan across
from right to left. We'll use a while
loop and a for
loop to do this.
Type the following, pressing control-c to break out:
for pixel in range(7):
rh.rainbow.clear()
rh.rainbow.set_pixel(pixel, 255, 0, 0)
rh.rainbow.show()
time.sleep(0.1)
The red pixel should now be scanning across from right to left.
We introduced a couple of new functions here - time.sleep(0.1)
and
rh.rainbow.clear()
. The time.sleep(0.1)
allows us to introduce a small pause
of 0.1 seconds between lighting each pixel and therefore to set the animation
speed (decrease the number to speed it up, increase it to slow it down). The
rh.rainbow.clear()
clears any set pixels, and we call this function each time
at the top of our for
loop so that only a single pixel is lit at any one time.
Now, we'll use the set_all
function to control all of the pixels at once and
then make them scan through all the colours of the rainbow. Because this
function controls all of the pixels we don't have to pass a pixel number in,
just the RGB values.
To scan through the colours of the rainbow, we're going to use HSV colour and
convert it to RGB before passing it to the set_all
function. HSV colour is
handy for this because the H of the HSV controls the hue of the colour and
represents a position around the colour wheel. This means that we can just
cycle around and transition between all of the colours of the rainbow.
import colorsys
rh.rainbow.clear()
for i in range(101):
h = i / 100.0
rh.rainbow.set_all(r, g, b)
rh.rainbow.show()
time.sleep(0.02)
This is pretty complex, so let's look at each step. First, we had to import the
colorsys
library to use its hsv_to_rgb
function to convert our HSV colour to
RGB.
Again, we're using a while True
loop that will run continuously and then a
for
loop inside that. The for
loop is what will cycle through the hues in
the colour wheel. Conveniently, 0 and 1 are both at the same position on the
wheel, so we just have to go from 0 up to 1 then start again at 0. We're just
using a range of numbers from 0 to 100 and dividing them by 100 to get 101
values between 0 and 1 (where it says h = i / 100.0
The line that says r, g, b = [int(c * 255) for c in colorsys.hsv_to_rgb(h, 1.0, 1.0)]
converts our HSV colours to RGB. Because the hsv_to_rgb
function both accepts
and returns colour values between 0 and 1, and we need numbers between 0 and 255,
we're using a list comprehension to multiply the RGB values we get back by 255
and also convert them back into integers (where it says int(c * 255)
). List
comprehensions are really handy ways to run the same operation on several things
at once and take the form [function(x) for x in y]
. They return a list. We're
also using list unpacking (r, g, b =
) to assign the resulting list of three
values straight to three variables r
, g
, and b
Finally, we're just using set_all
to set the RGB values on all of the pixels,
and the show
function to update the pixels and show the colour, with a small
delay of 0.02 seconds so that the rainbow cycles once every two seconds (since
we have about 100 values).
The 14-segment displays
Because we've used 14-segment displays on Rainbow HAT rather than the more commonly-used 7-segment displays, we can display both numbers and upper and/or lower case text on them. There's also four decimal points that come in handy when displaying floating point numbers.
All of the display functions are collected together into the display
module,
and be accessed under rh.display
. The two functions we'll be looking at here
are print_str
and print_float
, which print strings and floating point
numbers respectively, as you may have guessed!
We're going to print the string AHOY
to the displays. Similar to the rainbow
pixels, the displays have a show
method, so after you've used print_str
you
also have call show
to update the displays with your string.
Type the following:
rh.display.print_str('AHOY')
rh.display.show()
As well as being able to display text and numbers, there's support for most of the commonly-used special characters like @ and such.
Now, we'll use the print_float
function to display some floating point numbers,
inside a while
loop that adds 0.01 each time, in effect creating a counter.
i = 0.0
while i < 999.9:
rh.display.clear()
rh.display.print_float(i)
rh.display.show()
i += 0.01
This starts at 0.0, clears the display, then uses the print_float
method and
show
to display the current value of i
, and finally increments i
by 0.01.
You can also control the four decimal points, which is especially handy if you
want to do something like make a clock. The set_decimal
function takes two
arguments - the position of the decimal point you want to toggle on, and a
True
or False
value depending on whether you want to turn it on or off. The
decimal points are numbered 0-3 from left to right.
Type the following to toggle on the first decimal point:
rh.display.clear()
rh.display.set_decimal(0, True)
rh.display.show()
Touch pads and LEDs
Rainbow HAT has three capacitive touch pads, marked A, B, and C, each with a coloured LED above. The touch pads can be used with decorator functions to link a touch and/or release event to a function. Decorators in Python are added directly before your function definition, allowing the function to be called automatically when the decorator is triggered, and can pass data into the function as well.
The LEDs associated with the touch pads can be controlled independently. Here, we'll link the LED above touch pad A to the touch pad, so that when the touch pad is pressed the LED lights up.
Type the following:
@rh.touch.A.press()
def touch_a(channel):
print('Button A pressed')
rh.lights.rgb(1, 0, 0)
@rh.touch.A.release()
def release_a(channel):
print('Button A released')
rh.lights.rgb(0, 0, 0)
You'll see that the touch pads - A, B, and C - are referred to in the decorator
line as @rh.touch.A
, @rh.touch.B
, and @rh.touch.C
, and that they have both
press()
and release()
methods. Our two functions - touch_a
and release_a
are triggered by the generator when the pad is touched or released, and we light
the LED with rh.lights.rgb(1, 0, 0)
To control the LEDs above the pads, you pass either a 1 (to switch on) or a 0
(to switch off) to the rh.lights.rgb
function. The three numbers passed
correspond to each of the three LEDs in turn, meaning that you can toggle
several on or off at the same time.
Type the following to turn all three LEDs on:
rh.lights.rgb(1, 1, 1)
And type the following to switch them off again:
Temperature and pressure
The BMP280 sensor on Rainbow HAT measures both temperature and pressure. It's
really simple to read the current temperature and pressure. Both are under the
rh.weather
module, so temperature can be read with rh.weather.temperature()
and pressure with rh.weather.pressure()
t = rh.weather.temperature()
p = rh.weather.pressure()
print(t, p)
time.sleep(0.5)
That should print the temperature in degrees Celsius and the pressure in Pascals (divide by 100 to get the more commonly-used hectoPascals) every half second.
You could easily modify that code to display the temperature on the 14-segment
displays, using the print_float
method, as follows:
rh.display.clear()
rh.display.print_float(t)
rh.display.show()
time.sleep(0.5)
Piezo buzzer
The piezo buzzer allows you to play notes of specific frequencies, or midi note
numbers. Let's begin by playing a note of a specific frequency, middle C which
has a frequency of 261Hz. The buzzer methods are under the buzzer module,
rh.buzzer
, and the note
method takes a frequency in Hz and a note length in
seconds.
Type the following:
rh.buzzer.note(261, 1)
That should play middle C for 1 second. Next, we'll do that same but with the
midi_note
function that allows you to use midi note numbers. Middle C is midi
note 60, so we'll play that now.
Type the following:
rh.buzzer.midi_note(60, 1)
To play a tune, you could make a list of the notes, and then loop through them, with a short pause after each one.
Type the following:
song = [68, 68, 68, 69, 70, 70, 69, 70, 71, 72]
for note in song:
rh.buzzer.midi_note(note, 0.5)
time.sleep(1)
It's worth noting that if you want a half second note and then a half second pause, you'll add your note length to the length of your pause, e.g. 0.5 + 0.5 = 1 in the example above.
Also, the notes we've used are all of the same length and ideally you'd want to vary the note length to make the tune sound correct.
Did you guess what song that was?
Project ideas
The variety of different inputs and outputs on Rainbow HAT makes it ideal for all sorts of projects, combining the inputs and outputs in interesting ways and applying what you've learned above.
Here are some ideas we've had:
Weather station
Use the temperature and pressure sensor, and display the values on the 14-segment displays. You could even use the rainbow LEDs to display a bar chart of the temperature or pressure with the colour indicating cold or warm temperatures, or low or high pressure. Why not make it internet-connected and tweet the values, or log the values to a Google Sheet?
Tiny, three-note piano
There are plenty of tunes you can play with three notes! Here’s one to get you started - Mary Had a Little Lamb. The piezo buzzer uses PWM (pulse width modulation) to generate different frequencies of sound, and it’s easy to map these frequencies to notes. You could even use chording to get up to eight notes!
Reaction time game
Use the buttons to make a reaction time game for up to three players. Press a button to start, and when the rainbow lights change from red to green the first player to hit their button is the winner. Display the winning time on the 14-segment displays.
Stopwatch or countdown timer
Use the buttons as controls for starting or stopping a stopwatch, and display the time on the 14-segment displays. You could use the rainbow LEDs to display the seconds ticking. Or use the buttons to set the seconds and minutes on a countdown timer, displaying the countdown on the displays, and then buzz the buzzer when the time is up!
Mood light
Set your mood with the rainbow LEDs, using the 3 buttons to select and adjust each colour channel, fade through the hue, or switch between lighting effects.
