Advanced
Build a Home Assistant Touchscreen Controller with Presto
Use Presto, MQTT and Zigbee to switch smart plugs, show live power use and get doorbell alerts from Home Assistant.
6 November 2026 · Tutorial · about 1.5 hours
What if one device could enable you to turn on devices, read power consumption and notify you of visitors? Such a device is possible and in this guide we will build it using Presto, our RP2350-powered desktop companion. The entire 4 inch square, 480 x 480 pixel display will be used to keep total control of our smart home devices.
What Are The Project Goals?
  • To control sockets / devices over Home Assistant.
  • Report device power consumption.
  • React when the doorbell is pressed.
We break down the project into sections before launching into the code.
  • Set up MQTT.
  • Set up Zigbee.
  • Connect Zigbee devices to control them.
  • Receive live power data using a Zigbee to MQTT bridge.
  • React to a doorbell press.
Setting Up Home Assistant
Home Assistant is an open source, smart home automation tool that enables owners to connect to a range of devices. These devices can be smart power sockets, temperature sensors, window / door sensors, even water leak sensors. The goal of Home Assistant is to enable anyone to easily add smart technology to their home, without sending data to external parties.
We're using Home Assistant Green, a ready to go Home Assistant server. Alternatively, you can build your own, using a Raspberry Pi 4 or better (even an old laptop or x86 PC would do the job) and a Sonoff Zigbee 3.0 dongle, but we won't be covering that in this guide.
Home Assistant is extremely configurable, but our focus is on just two features. MQTT and Zigbee.
  • MQTT is a lightweight protocol for transferring data. It uses a publish / subscribe model that is very similar in concept to YouTube. Devices can publish information (like a content creator) which is sent to a broker (YouTube) who serves the content to subscribers.
  • Zigbee is a power efficient radio protocol that is common in most smart home projects.
Setting Up MQTT
MQTT is the glue for this project. Presto cannot directly connect to a Zigbee device, so our Home Assistant server will bridge the traffic between MQTT and Zigbee. To use Zigbee, our Home Assistant Green has a Home Assistant Connect ZBT-2 antenna. It also works with competing protocols like Matter or Thread. The antenna is plug and play, so we can concentrate on getting our project started without any additional configuration.
Our first task is to set up MQTT on our Home Assistant server.
  1. Open Home Assistant in a browser and go to Settings >> Apps. Your Home Assistant install is typically configured to http://homeassistant.local but check this before moving forward. The Home Assistant Settings menu and an arrow pointing to Apps.
  2. Click on Install App. Blue install app button.
  3. Search for Mosquitto and click to open the app page. Search dialog in the App store.
  4. Click on Install. Blue install app button highlighted on project page.
  5. Set Mosquitto to start on boot, run a watchdog (to restart if it crashes) and to auto-update. Then click on Start to activate the Mosquitto MQTT broker. Blue button for auto-starting MQTT on boot.
  6. Now go to Settings >> People. Arrow pointing to Settings >> Users
  7. Click on Users tab. The Users tab.
  8. Click on Add User button Blue Add User button.
  9. Create a new mqtt-user and give the account a strong password. Set the user to have local access. Click Create when done. Add user dialog with entries for name and password.
  10. Click on Settings and look to the top right of the screen for three dots. Click there and select Restart Home Assistant. Doing this ensures that our changes are freshly updated and ready for use. Restart Home Assistant is highlighted.
  11. Select a full restart of Home Assistant. Wait for the restart to finish before moving on. This can take a couple of minutes. Restart Home Assistant highlighted and ready for use.
  12. Click on Settings >> Devices & Services. The devices and services listing
  13. Click on Add. Home Assistant will automatically discover MQTT. The add button is highlighted for MQTT
  14. Click on Submit to automatically configure the MQTT broker. Click Finish when prompted. Dialog asking to add the MQTT broker to Home Assistant
  15. Click on Settings >> Devices & Services and then MQTT. MQTT highlighted in a grid of services
  16. Click on the three dots and select Reconfigure. Reconfiguring MQTT setup
  17. Change the MQTT username and password to the user account that we created earlier and then click Submit. Setting up the MQTT user to use the MQTT service
MQTT is now configured and ready for use. Now let's turn our attention to setting up our Zigbee devices.
Connecting a Zigbee Device to Home Assistant
There are two main Zigbee devices in this project.
Both of these will need to be connected to our Home Assistant setup before we can build the project.
  1. Connect your Zigbee device to a power source and it will enter pairing mode. This is the default behaviour when first using a Zigbee device. If the device doesn't enter pairing mode, follow the guide for your Zigbee device to start pairing mode. Typically this is a long press of a button. If the device has been used before, its entry will need to be deleted in Home Assistant before pairing can occur.
  2. Open Home Assistant in a browser window and click on + >> Add Device. The + is found in the top right corner of the window. The Add Device option in Home Assistant
  3. Select Add Zigbee device. This will start a search for any Zigbee devices which are in pairing mode. Add Zigbee device option
  4. The Zigbee interview process will start and in a short while your device will be ready for use. The Interview process is where Home Assistant determines what features (entities) the Zigbee device has. At this step, you can optionally give the device a unique name and place it in an area. When done, click on the left arrow next to Add device. The Zigbee Interview process dialog
Repeat this process for all of the Zigbee devices that you wish to connect. Our next task is to trigger the device on / off using a specially crafted MQTT message.
Controlling a Zigbee Device Using MQTT
We're going to create automations to turn the Sonoff Smart Plugs on and off. You will need to repeat these steps for all of the smart plugs and other Zigbee devices that you wish to control.
  1. Click on + >> Create automation. The + is found in the top right corner of the window. Selecting New Automation
  2. Select Create new automation from the list. Selecting new automation from a list of entries
  3. Under When, click on + Add Trigger. Selecting Add Trigger under when
  4. Click on Type, then select MQTT from the list. Then select MQTT message received. Selecting the correct MQTT function
  5. Set the Payload to ON and the Topic to office/skull. An illuminated skull was a recent discount store purchase, which is now connected to a smart plug. Setting the payload (message) for the MQTT topic
  6. Under Then, click on + Add action. Adding an action that will be triggered
  7. Click on By target and then select the location and the device that you want to control. Then, select Turn on switch. This will turn on power to the skull device. Selecting the action
  8. At the bottom of the screen, click on Save and in the new dialog give the automation a clear name and click on Add area and set the location of the device. Finally, click on Save Saving the automation
  9. Repeat this process with the same topic but this time use Turn off switch and set the payload to OFF to turn off the device. Automation to turn off the device
Live Power Details Over MQTT
Our Presto Home Assistant app will have buttons that control Sonoff Zigbee Smart Plug sockets, turning them on / off. But we also want to see how much power a socket is consuming. To do that we need to tell Home Assistant to send data via MQTT. Presto will be configured to listen for a specific topic for each socket and that will provide the power usage text for that button.
Below is a matrix for our Presto Home Assistant controller setup for three Sonoff sockets that will report power usage to the Presto app.
Button Name Sensor Name MQTT Power Topic
PC sensor.pc_power home/devices/pc/power
Prusa sensor.prusa_core_one_power home/devices/prusa/power
Workbench sensor.workbench_power home/devices/workbench/power
You will need to change the name of the button / sensor / power topic according to how you have configured your Home Assistant set up.
  2. Select Create new automation from the list. Create a new automation
  4. Select By target >> Time and then select Time pattern. Selecting the time pattern trigger
  5. Set the trigger to happen every 10 seconds using /10 in the Seconds field. Notice how the text under When changes to show how often the trigger will action. Setting the trigger to occur every 10 seconds
  6. Under And if click on Add condition. Adding an extra condition
  7. Select By type and then scroll down to Template and then select Template Adding a template
  8. Add this code to the template. Note: This is for reading the sensor inside my PC Zigbee device, which is a Sonoff Zigbee Smart Plug (Type G). You may need to change this to reflect your setup and device names. My PC socket is called PC and we are using the sensor to read the power. If you start typing the name of the device, sensor.pc_ then the editor will suggest suitable targets.
    {{ states('sensor.pc_power') not in ['unknown', 'unavailable', 'none'] }}
    The template for taking a power reading
  9. Click on Add action. Add action button
  10. Select By Type and scroll down to MQTT and then select MQTT: Publish. Selecting By Type to search for MQTT
  11. Set the topic to be home/devices/pc/power and set the payload to the code below. The payload is the Sonoff Zigbee Smart Plug's power sensor data, rounded to one decimal place. The topic is the channel where our subscriber (Presto) is waiting to hear via the broker. Change home/devices/pc/power and sensor.pc_power to the names of the devices that you are using.
    {{ states('sensor.pc_power') | float(0) | round(1) }}
    The MQTT publish setup dialog
  12. Select Save and give your automation a clear and relevant name, description and assign it an area before clicking Save. Saving the automation
  13. Repeat these steps for any other sockets that you wish to monitor.
Adding a Doorbell
The doorbell is a Sonoff Zigbee Wireless Switch inside of a handy 3D printed case. When the doorbell is pressed, it will send a Zigbee signal to Home Assistant Green, which will then trigger an MQTT message to be published. Presto will be subscribed to the doorbell topic and will react accordingly.
We're going to assume that you have already followed the steps in Connecting a Zigbee Device to Home Assistant and that your Sonoff Zigbee Wireless Switch is ready to be used. If not, go back and do so.
  1. Click on Settings >> Devices & Services. Opening settings and navigating to devices and services
  2. Select Zigbee Home Automation. Select Zigbee automation
  3. Select the eWeLink SNZB-01P (Sonoff SNZB-01P) button. Select the doorbell device
  4. Under Related, click on Add to. The related section is highlighted
  5. Click on Create a New Trigger. In Home Assistant parlance, this is called an Automation. Creating a new trigger
  6. Set "When" the button is pressed. Creating the automation
  7. Click on Add Action which is under "Then Do". The Add Action button is highlighted
  8. Scroll down the list to MQTT and select MQTT Publish Locating MQTT Publish
  9. Set the topic to doorbell and the payload to doorbell. Click on Save. Setting the payload
  10. Name the automation "Doorbell" and click Save. Giving the automation a name
That is all of the MQTT broker setup complete. We have a device, our Sonoff button, which when pressed will trigger Home Assistant to publish an MQTT message to the broker.
Writing The Code
Before we can write any project code, we first need to edit a file called secrets.py. This file contains all of our secret information, passwords, API keys, Wi-Fi credentials. The file lives in the root of Presto's file system and it should not be shared or placed in a public version control system.
  1. In Thonny, click on File >> Open and select Raspberry Pi Pico.
  2. Select secrets.py.
  3. Tweak the file to have four constants for your WIFI_SSID, WIFI_PASSWORD, MQTT_USERNAME and MQTT_PASSWORD.
    WIFI_SSID = "YOUR WIFI AP SSID"
    WIFI_PASSWORD = "YOUR WI-FI PASSWORD"
    MQTT_USERNAME = "YOUR MQTT USERNAME FROM HOME ASSISTANT"
    MQTT_PASSWORD = "YOUR MQTT PASSWORD FROM HOME ASSISTANT"
  4. Click on File >> Save to save the secrets.py to Presto.
  5. In a new blank file, start with three lines that create an icon, name and description that are displayed on Presto's launcher.
    # ICON lightbulb
    # NAME Home Assistant Controller
    # DESC Control your smart home
  6. Import a series of modules (pre-written code) to add the following features to the code.
    1. Presto: This module enables us to control and communicate with Presto.
    2. Umqtt: A simplified MQTT client that we will use to publish and subscribe on the MQTT network.
    3. Time: Used to control the pace of the code using delays.
    4. Gc: Garbage collection, used when closing the app or when it hits an exception.
    5. Network: Enables Presto to connect to Wi-Fi.
    6. Secrets: A file that contains usernames and passwords that we don't want to hard code.
    from presto import Presto, Buzzer
    from umqtt.simple import MQTTClient
    import gc
    import network
    import secrets
  7. Create variables to use Presto, its display, touchscreen and buzzer.
    presto = Presto(full_res=True)
    display = presto.display
    touch = presto.touch
    buzzer = Buzzer(43)
  8. Store the screen width and height in constants. These values will not change, during the operation of the code, so using constants makes sense. Constants are set once and then used, but never updated. Unlike variables, which can be set and updated during the operation of the code.
    WIDTH, HEIGHT = display.get_bounds()
  9. Generate a series of constants for colours used in the app. These are used to create buttons and backgrounds in the app.
    BG    = display.create_pen(20, 24, 32)
    WHITE = display.create_pen(255, 255, 255)
    GREY  = display.create_pen(60, 60, 60)
    RED   = display.create_pen(170, 40, 40)
    GREEN = display.create_pen(30, 170, 70)
    AMBER = display.create_pen(230, 160, 20)
  10. Create constants for the Wi-Fi SSID and password for your router. These constants are generated from their respective entries in secrets.py.
    SSID     = secrets.WIFI_SSID
    PASSWORD = secrets.WIFI_PASSWORD
  11. Configure MQTT using constants for the broker, port, client-id, username and password. The broker is the device running an MQTT service. In this case it is a Home Assistant Green. The broker constant can use the URL or IP address of the broker. If there are issues connecting to the URL, use the IP address. The port is typically 1883 but this can be tweaked according to your own setup. The client id must be unique, otherwise errors will occur. The MQTT username and password are those that were set up in the Home Assistant MQTT service. The DOORBELL_TOPIC is the channel that the publisher sends messages to via the broker. The subscriber (Presto) waits for new messages on this channel.
    MQTT_BROKER   = "homeassistant.local"
    MQTT_PORT     = 1883
    CLIENT_ID     = "presto-office"
    MQTT_USERNAME = secrets.MQTT_USERNAME
    MQTT_PASSWORD = secrets.MQTT_PASSWORD
    DOORBELL_TOPIC = b"doorbell"
  12. Create constants for the doorbell button. The button flash animation runs for 15 seconds, 15,000 milliseconds and flashes at 500ms. This gives us a clear on-screen indication that the doorbell has been pressed.
    RING_MS = 15000
    FLASH_MS = 500
  13. Create the doorbell tone and set the duration for which it plays. A middle C is approximately 261 Hz, and it has enough presence to be clearly heard, without becoming shrill. The duration of 100ms is used for the duration of the beep, creating a pleasant ringing sound.
    BEEP_HZ = 261
    BEEP_MS = 100
  14. Use a list, SWITCHES to store the name of each on-screen button, and its MQTT topic. The ROUTER and SPEAKERS buttons are placeholders, change these as you see fit. The button name and MQTT topic are stored as tuples that are collected inside the list.
    SWITCHES = [
        ("PC",        b"office/pc"),
        ("PRUSA",     b"office/prusa"),
        ("WORKBENCH", b"office/workbench"),
        ("DOORBELL",  DOORBELL_TOPIC),
        ("BANANA",    b"office/banana"),
        ("SKULL",     b"office/skull"),
        ("ROUTER",    b"office/router"),
        ("SPEAKERS",  b"office/speakers"),
  15. Create two payloads. One for on, the other, off. Payloads are the messages sent to an MQTT topic. We're using them to turn devices on / off.
    PAYLOAD_ON  = b"ON"
    PAYLOAD_OFF = b"OFF"
  16. Use a constant, DOUBLE_TAP_MS to set the delay window to double tap a button. Each of the buttons requires a double tap to turn on / off, and 600ms (0.6 seconds) is just long enough to read the double tap. Why is there a double tap? Because we don't want to accidentally turn off a device if we press the wrong button.
    DOUBLE_TAP_MS = 600
  17. Create a states dictionary to record the state of each button. This can be True (on), False (off) or None.
    states = {topic: None for _, topic in SWITCHES}
  18. Create a dictionary to store the sockets for which we want to monitor the power. In the office, we have three sockets, PC, Prusa and Workbench that we want to monitor the power consumption. These MQTT topics will enable the live power data to be read and used in the app.
    POWER_TOPICS = {
        b"office/pc":        b"home/devices/pc/power",
        b"office/prusa":     b"home/devices/prusa/power",
        b"office/workbench": b"home/devices/workbench/power",
  19. Store the latest power reading for each device in POWER_TOPICS.
    watts = {topic: None for topic in POWER_TOPICS}
  20. Create a dictionary called "ring" and use it to store the doorbell alert status. This is until when idle, and phase is used to flash the button using quick colour swaps between amber and grey.
    ring = {"until": None, "phase": 0}
  21. Create the columns and rows that will make up the button layout. Then set the gap for the top of the screen and the space around the buttons The height of the gap is 44 pixels and each button on the display has a 10 pixel buffer around it. This provides a clear distinction between the buttons.
    COLS = 2
    ROWS = 4
    TOP = 44
    GAP = 10
  22. Using basic maths skills we calculate the button width BTN_W and height BTN_H.
    BTN_W = (WIDTH - GAP * (COLS + 1)) // COLS
    BTN_H = (HEIGHT - TOP - GAP * (ROWS + 1)) // ROWS
  23. Set the status text and colour before they are used. The "Starting..." text is used when the app first starts up.
    status = "Starting..."
    status_pen = AMBER
  24. Create a function button_rect() that turns a button’s number into its position in the grid. The buttons fill left to right, then down. The same function is also used for drawing and working out which button was touched, so the two always match.
    def button_rect(i):
        col = i % COLS
        row = i // COLS
        return (GAP + col * (BTN_W + GAP),
                TOP + GAP + row * (BTN_H + GAP),
                BTN_W, BTN_H)
  25. Create a function to control the buzzer's tone and duration. This uses the BEEP_HZ and BEEP_MS to set the tone (middle C, 261 Hz) and the duration (100ms).
    def beep():
        buzzer.set_tone(BEEP_HZ)
        time.sleep(BEEP_MS / 1000)
        buzzer.set_tone(0)
  26. Another function, this time it controls the seven RGB LEDs on the rear of Presto. This will set the LEDs to amber when the doorbell is pushed.
    def set_leds(r, g, b):
        for n in range(7):
            presto.set_led_rgb(n, r, g, b)
  27. Create a function, draw() to handle the following tasks.
    1. At the top of the screen, clear to the background colour and write the status line.
    2. Work out the colour and state text for each button.
    3. For the doorbell button if the doorbell has been pressed, set the button colour to amber and grey. This creates the flashing effect. If idle, it shows a dark grey button with Ready text.
    4. For every other button, the colour green means the device is on, and red means off. Grey is used if the status is unknown.
    5. Draw the button rectangle and the device name in the centre.
    6. Power topic buttons show Watts to one decimal place and the device's state (on, off). If there is no data, it displays -- W.
    7. The entire screen is updated to show the data.
    def draw():
        display.set_pen(BG)
        display.clear()
        display.set_pen(status_pen)
        display.text(status, GAP, 8, WIDTH - 2 * GAP, 3)
        for i, (name, topic) in enumerate(SWITCHES):
            x, y, w, h = button_rect(i)
            if topic == DOORBELL_TOPIC:
                if ring["until"] is not None:
                    colour = AMBER if ring["phase"] else GREY
                    state = "RINGING!"
                    colour = GREY
                    state = "Ready"
                on = states[topic]
                colour = GREEN if on else RED if on is False else GREY
                state = "ON" if on else "OFF"
            display.set_pen(colour)
            display.rectangle(x, y, w, h)
            display.set_pen(WHITE)
            display.text(name, x + (w - display.measure_text(name, 3)) // 2, y + h // 2 - 24, w, 3)
            if topic in POWER_TOPICS:
                w_val = watts[topic]
                state += "  " + (f"{w_val:.1f} W" if w_val is not None else "-- W")
            display.text(state, x + (w - display.measure_text(state, 2)) // 2, y + h // 2 + 6, w, 2)
        presto.update()
  28. Update the status line at the top of the screen and redraw.
    def set_status(text, pen=WHITE):
        global status, status_pen
        status = text
        status_pen = pen
        draw()
  29. Create a function to handle when the doorbell is pressed. This function will set the deadline RING_MS from the time the button is pressed. Then it sets the phase to amber which turns the LEDs on the rear of Presto amber and shows “Doorbell!” at the top of the screen.
    def start_ring():
        was_amber = ring["until"] is not None and ring["phase"] == 1
        ring["until"] = time.ticks_add(time.ticks_ms(), RING_MS)
        ring["phase"] = 1
        set_leds(230, 160, 20)
        set_status("Doorbell!", AMBER)
        if not was_amber:
            beep()
  30. Create a function to handle the end of ringing the doorbell. This will clear the deadline, and swap the "Doorbell!" status text at the top of the screen for "Connected". The LEDs and onscreen Doorbell button are reset to their defaults.
    def end_ring():
        was_amber = ring["phase"] == 1
        ring["until"] = None
        ring["phase"] = 0
        set_leds(0, 0, 0)
        set_status("Connected", GREEN)
        if was_amber:
            beep()
  31. Use a function to connect to Wi-Fi. This function takes arguments for the Wi-Fi SSID and password. It creates an object, wlan that is used to communicate with the Wi-Fi chip and make a connection to our Wi-Fi router. It handles timeout errors, and will keep trying to connect every 0.5 seconds for 20 seconds. For debug purposes, it prints the connection details to the Python shell.
    def connect_wifi(ssid, password, timeout=20):
        wlan = network.WLAN(network.STA_IF)
        wlan.active(True)
        if not wlan.isconnected():
            wlan.connect(ssid, password)
            start = time.time()
            while not wlan.isconnected():
                if time.time() - start > timeout:
                    raise RuntimeError("WiFi timeout")
                time.sleep(0.5)
        print(f"Connected! IP: {wlan.ifconfig()[0]}")
        return wlan
  32. Create a function that handles receiving messages and reacting accordingly. If the message is DOORBELL_TOPIC a message is printed to the Python shell for debug, before calling the start_ring() function.
    def on_message(topic, msg):
            print(f"Doorbell: {msg}")
            start_ring()
            return
  33. Still inside the function, create a for loop that iterates over POWER_TOPICS entries. It rounds the returned values to one decimal place, and writes the values on the corresponding buttons. It also handles value errors by printing an error message to the Python shell.
        for sw_topic, power_topic in POWER_TOPICS.items():
            if topic == power_topic:
                    value = round(float(msg.decode()), 1)
                except ValueError:
                    print(f"Bad power payload: {msg}")
                    return
                if value != watts[sw_topic]:
                    watts[sw_topic] = value
                    draw()
  34. The main() function is where we call the other functions to run the code. First we create a client object that handles the MQTT connection details. We also set the MQTT callback function, used when a message arrives, to call the on_message() function.
    def main():
        client = MQTTClient(
            client_id=CLIENT_ID,
            server=MQTT_BROKER,
            port=MQTT_PORT,
            user=MQTT_USERNAME,
            password=MQTT_PASSWORD,
        client.set_callback(on_message)
  35. Inside a try / finally statement, connect to the MQTT broker, printing a success message to the Python shell. Then subscribe to the DOORBELL_TOPIC.
            client.connect()
            print(f"Connected to MQTT broker {MQTT_BROKER}")
            client.subscribe(DOORBELL_TOPIC)
            print(f"Subscribed to: {DOORBELL_TOPIC.decode()}")
  36. Using a for loop, iterate over the POWER_TOPICS items and subscribe to the relevant power_topic value and then set_status to print a green "Connected" message to the top of the screen.
            for power_topic in POWER_TOPICS.values():
                client.subscribe(power_topic)
                print(f"Subscribed to: {power_topic.decode()}")
  37. Create three variables that are used to store the status of the touchscreen, which button was recently touched, and the last time that button was tapped.
            was_touching = False
            last_tap_index = None
            last_tap_time = 0
  38. Using a while True loop, check for any messages.
                client.check_msg()
  39. Animate the doorbell button by swapping its colour for 15 seconds and playing the beep() function. When the time is up, the end_ring() function is called.
                    remaining = time.ticks_diff(ring["until"], time.ticks_ms())
                    if remaining <= 0:
                        end_ring()
                        phase = (remaining // FLASH_MS) % 2
                        if phase != ring["phase"]:
                            ring["phase"] = phase
                            draw()
                            beep()
  40. Check for touch input and locate where the touch was on the screen. Holding a finger on the screen will count as one touch. We have to remove the finger and press the screen again for a double tap. This section also handles cancelling the doorbell alert early. Touching the DOORBELL button while it is flashing will cancel the doorbell.
                touch.poll()
                if touch.state and not was_touching:
                        if x <= touch.x < x + w and y <= touch.y < y + h:
                                # Indicator only: a tap just clears the alert
                                    end_ring()
                                break
  41. Get the current time (in ticks) and save it to a variable called now.
                            now = time.ticks_ms()
  42. Use the current time and an if conditional test to check if the button has been double tapped. If so send the correct payload to turn the device on / off and then change the status text for the relevant button.
                            if i == last_tap_index and time.ticks_diff(now, last_tap_time) < DOUBLE_TAP_MS:
                                on = not states[topic]
                                payload = PAYLOAD_ON if on else PAYLOAD_OFF
                                client.publish(topic, payload)
                                print(f"Sent {topic.decode()} {payload.decode()}")
                                states[topic] = on
                                set_status(f"{name} {'ON' if on else 'OFF'}", GREEN)
  43. Add an else condition which will advise the user to double tap the buttons.
                                last_tap_index = i
                                last_tap_time = now
                                set_status(f"Double tap {name}", AMBER)
  44. Break out of the loop, update the was_touching variable with the current touch state, then pause for 0.02 seconds.
                            break
                was_touching = touch.state
                time.sleep(0.02)
  45. End the try / finally statement, close the MQTT connection and then handle any errors when closing the connection.
        finally:
                client.sock.close()
            except Exception:
                pass
  46. Call the draw() function to update the screen.
    draw()
  47. Inside a while True loop, use try to set the text at the top of the screen to show "Wi-Fi", then connect to Wi-Fi. Next we update the text at the top of screen to show "MQTT..." and then call the main() function.
            set_status("Wi-Fi...", AMBER)
            connect_wifi(SSID, PASSWORD)
            set_status("MQTT...", AMBER)
            main()
  48. Capture any exceptions and print them to the Python shell. We then use garbage collection to free-up memory before the code pauses for five seconds.
        except Exception as e:
            print(f"Error: {e}")
            set_status("Retrying...", RED)
            gc.collect()
            time.sleep(5)
  49. Save the code to Presto as HA-Controller.py
  50. Press RESET on Presto and when it has rebooted, scroll to and select the Home Assistant Controller.
  51. When Wi-Fi and MQTT are connected, the status text (top of screen) will show "Connected"
  52. Double-tap the relevant buttons to control your devices. The buttons will all be grey until they are pressed. Buttons which are set to show power stats will show either a blank -- W or the real-time power consumption data.
  53. Ask someone to trigger your doorbell. You will see the DOORBELL button flash, the LEDs will light-up and the buzzer will sound. You can touch the button to cancel the doorbell, or wait 15 seconds for it to automatically end.
Complete Code Listing
# ICON lightbulb
import gc
import network
import secrets
buzzer = Buzzer(43)
MQTT_PORT     = 1883
# Doorbell button config.
# Lights up when any message is received on `doorbell` topic.
# Tapping the button clears the alert.
RING_MS = 15000    # how long the button keeps flashing (ms)
FLASH_MS = 500     # flash speed (ms)
BEEP_HZ = 261      # buzzer pitch
BEEP_MS = 100      # buzzer beep length
# The buttons that appear on Presto's screen.
# One button per topic: (label, topic)
SWITCHES = [
PAYLOAD_ON  = b"ON"
# Two taps on the same button within this time (ms) will publish the message via MQTT
DOUBLE_TAP_MS = 600
# Smart Plug status
# True = on, False = off, None = not known yet
# Power consumption: Topic that reports its power draw in watts (plain number payload)
POWER_TOPICS = {
# Doorbell alert: "until" is a ticks_ms deadline (None = not ringing)
# "phase" 1 = button amber, 0 = button grey
COLS = 2
ROWS = 4
TOP = 44
GAP = 10
status_pen = AMBER
def button_rect(i):
    col = i % COLS
    row = i // COLS
            BTN_W, BTN_H)
def beep():
    buzzer.set_tone(0)
    for n in range(7):
def draw():
    display.set_pen(BG)
    display.clear()
                state = "RINGING!"
                colour = GREY
                state = "Ready"
            on = states[topic]
    presto.update()
    status = text
    status_pen = pen
    draw()
def start_ring():
    # Button goes amber: beep if that is a colour change
    ring["phase"] = 1
    if not was_amber:
        beep()
def end_ring():
    # Button goes back to grey: beep if it was amber
    ring["phase"] = 0
    set_leds(0, 0, 0)
    if was_amber:
        beep()
    wlan.active(True)
        start = time.time()
            time.sleep(0.5)
    return wlan
        start_ring()
        return
            except ValueError:
                return
                draw()
def main():
        server=MQTT_BROKER,
        port=MQTT_PORT,
        user=MQTT_USERNAME,
        client.connect()
        last_tap_time = 0
            client.check_msg()
            # Doorbell Notification: Flash the doorbell button (beep on every colour change), stop after RING_MS
                if remaining <= 0:
                    end_ring()
                        draw()
                        beep()
            touch.poll()
                                end_ring()
                            break
                            # Second tap in time: toggle and send
                            states[topic] = on
                            # First tap: wait for the second
                            last_tap_index = i
                            last_tap_time = now
                        break
            time.sleep(0.02)
    finally:
            client.sock.close()
        except Exception:
            pass
draw()
        main()
        gc.collect()
        time.sleep(5)
  • How to connect Zigbee devices to Home Assistant.
  • How to set up and connect to an MQTT broker.
  • How to publish and subscribe to MQTT topics.
  • How to write a user interface for Presto.
